Do you find a difference between public/hi-ed and multi-fam/residential (development) projects for the CCA phase ? We do both types of work, but when it comes to CCA there seems to be a lack of understanding on how to use specifications for the work. For the Multi-Fam GC it's purely a vehicle for submittals. All other scope requirements are ignored. They want all these "directions" noted in the drawings! The specs are ignored and they say they don't read it! It's not a huge spec either 350 pages for Architectural sections.
This is my example- this is the situation for Multi-Family/Residential work:- The exposed steel equipment supports on the roof were not primed nor painted by GC. It's now rusting, (as exposed steel would here in So Cal). We pointed this out in the AFOR and indicated it needed to be primed and painted. Spec section 05 0513 - Shop Applied Steel Primer ; Section on Surface Preparation indicates the Application & Surface Preparation. Section 09 9100 - Painting states "Unless otherwise indicated, paint all surfaces throughout the Project, except the following.
a. Concrete.
b. Steel decking.
c. Roofing.
d. Insulation and its facing.
e. Finish hardware, except items specified with a USP finish.
f. Prefinished metal surfaces, including anodized aluminum, chrome plating, powder coatings, and similar pre-finished materials.
g. Natural finish metal surfaces, including mill finish aluminum, stainless steel, copper, bronze, brass and similar finished materials.
h. Walls or ceilings in concealed and inaccessible areas, including furred areas, chases, and shafts.
i. Moving, mechanical, or electrical parts of operating units, including valve and damper operator linkages, sensing devices, motor and fan shafts..
j. Nameplates and required labels, including UL, FM, and other equipment identification, performance rating, or name plates.
Where surfaces are not specifically indicated, paint them to match adjacent similar materials or areas. "
The GC has the Owner convinced we are at fault as there wasn't a "note" on the drawings. We believe the specification above is a sufficient, requiring priming for steel & painting of the exposed steel. The GC submitting a CO to the Owner & the Architect being blamed, (apparently the spec was never read to that level of detail, so it doesn't count!). This would not be the case for the public work. They read and comply. Steel in the same location on a public project is painted! Any thoughts on this or am I just dealing with "bad" actors (meaning a lesser quality of contractor than those doing public/commercial work). We have been documenting and copying the Owner to insure the liability paper-trail.
Janene Christopher AIA
Steinberg Hart
San Diego CA
