Expand all | Collapse all
Climate-Responsive Architecture and Building Performance: Lessons from Mongolia's Extreme Climate
  • 1.  Climate-Responsive Architecture and Building Performance: Lessons from Mongolia's Extreme Climate
    Posted 05-31-2026 01:47 PM
    From more than 24 years of architectural practice in Mongolia, I have learned that building performance is not determined solely by materials, technology, or design intent. It is fundamentally shaped by climate.
    Mongolia is one of the world's most extreme continental climate regions, where winter temperatures frequently drop to -30°C to -40°C (-22°F to -40°F), while summer temperatures can rise above +30°C to +35°C (86°F to 95°F). In such conditions, building envelope performance, façade systems, insulation strategies, and HVAC loads are directly influenced by architectural decisions made at the earliest design stages.
    However, in contemporary practice, there is an increasing tendency to apply standardized façade systems, glazing technologies, and "universal" design approaches across very different climate zones. While these solutions may appear efficient and modern, in practice they often lead to unintended consequences.
    Extensive glazed façades, for example, may perform adequately in mild climates but can significantly increase heat loss in cold regions. Conversely, in warm climates, the same systems can lead to excessive solar heat gain and increased cooling loads. In both cases, a single design strategy produces opposite performance failures depending on context.
    Similarly, lightweight façade systems that are efficient in temperate climates often fail to provide sufficient thermal mass, insulation continuity, or air-tightness in severe cold climates. As a result, indoor comfort is maintained primarily through mechanical systems rather than passive architectural design.
    This creates a condition where engineering systems compensate for what could have been resolved architecturally at the design stage, leading to:
    • Increased energy consumption
    • Higher operational costs
    • Greater carbon emissions
    • Long-term dependency on mechanical systems
    In my experience, principles developed in cold-climate architecture remain highly relevant today. These include:
    • Compact building forms to reduce heat loss
    • High-performance building envelopes
    • Continuous insulation and thermal bridge control
    • Careful window sizing and orientation strategies
    • Strategic use of thermal mass
    These principles not only reduce energy demand but also significantly improve overall building performance and resilience.
    The central challenge in contemporary architecture is no longer simply about adding technology, but about applying the right technology in the right climate context.
    This leads to a critical question:
    Rather than asking "Is this solution good?", we should ask: "Is this solution appropriate for this climate?"
    From my experience, climate should not be treated as a constraint, but as an active design partner in architecture.
    [Enkhbayar] [Enebish]
    ADEP LLC
    ulaanbaatar
  • 2.  RE: Climate-Responsive Architecture and Building Performance: Lessons from Mongolia's Extreme Climate
    Posted 06-02-2026 10:14 AM
    Thank you for this. This is part of the focus of an upcoming Building Perfornance KC x Resilience and Disaster Response webinar (see link below). When you have extremes of both kinds its got to be an incredible challenge to figure out the right balance of strategies to brace for the blistering cold but also last the super hot summers.
    The best enclosure design, and building design for that matter, must arise from a response to climate and to add to your point about thermal resilience, Id add wildfires, wind, floods and other climate events. The best enclosure in a specific climate may be at risk of going up in smoke because its built with a combustible construction type. Or the exterior wall could be code compliant but still be vulnerable to strong winds and sealant joints opening up because of too much movement. Dark colored materials in hot climates have their exterior cladding and sealant experience such high temperatures that they move much more and degrade much faster than lighter colors.
    We have to take cues from local building culture and how people built in these places before we had mechanical heating and cooling.
    Please to our webinar on July 14th 'Back to the Future: Combining Ancient Strategies with Modern Technology for Maximized Passive Survivability' and lets discuss more!
    Or come find me to braindate at the conference in San Diego!
    Jessica Saravia AIA
    DMAC Architecture & Interiors
    Evanston IL
