The response from Ron Geren, AIA is spot on. In my career, I have found that attorneys and contractors prefer to define an order of precedence as it provides simplicity for their purposes in interpreting the documents as opposed to the Architect being the interpreter and making reasonable judgements. Establishing an order of precedence for certain aspects of the Contract Documents may be desirable, particularly with respect to information issued subsequent to previously issued information. For example, addenda having precedent over previously issued documentation, although establishing precedent for such chronologically issued information is generally superfluous as the precedence is clear.
In no instance, however, should precedence be given to specifications over drawings, or vice versa. Specifications establish the level of quality and set forth other information such as the acceptable products and the processes to be followed. Drawings illustrate the extent and relationship of the physical elements of the project. These are quite different purposes which is why the specifications and drawings must be crafted to complement one another. It is difficult, if not impossible, to correlate such information if either the specifications or the drawings take precedent over the other.
In no case should submittals, including shop drawings, ever be included in an order of precedence as these are NOT Contract Documents and, therefore, they should never be considered to have any precedence.
Mark I. Baum, AIA
Mark I. Baum Architect LLC
New Orleans, LA
Original Message:
Sent: 03-12-2025 05:28 PM
Subject: Order of Precedence for Contract Documents
If you are using AIA Contract Documents, there is no precedence in the contract documents. AIA Document A201, Section 1.2.1, states, "The Contract Documents are complementary, and what is required by one shall be as binding as if required by all." If any document has precedence over another document, that would be the Owner-Contractor agreement. If there is a conflict in the Contract Documents, A201, Section 3.2.2, requires the contractor to review the Contract Documents and report promptly to the Architect "any errors, inconsistencies or omissions discovered."
Relying on an order of precedence could produce unexpected or unintended consequences.
Ronald Geren, AIA, FCSI, Distinguished Member, CCS, CCCA, CDT, SCIP
RLGA Technical Services LLC
Scottsdale AZ
Original Message:
Sent: 03-11-2025 12:36 PM
Is there a preferred order of precedence for Contract Docs? and if so which section in Div01 should it be listed. My understanding is that AIA contracts has tried to flatten the requirement and give equal weight to drawings vs specifications. This (AIA direction) I find to be confusing as typically this is where the most conflicts happen. Thoughts?
Janene Christopher AIA
Steinberg Hart
San Diego CA
