Do you need to lift the entire building? There are fairly standard procedures out there for underpinning/foundation replacement - it's a one third, two thirds pattern (excavate a 4'-0" section; remove and repour or underpin; skip the next 8'-0", do the next 4'-0" section, and so on). This may take longer, but not necessarily, and may be comparable in cost. If for whatever reason you really need to lift the entire building, then yes, house movers would be my first thought, as several others have said.
Katherine Dowdell AIA
Farragut Street Architects
Philadelphia PA
