  • 1.  BIM Coordination Model and Design-Build
    Posted 05-02-2025 06:32 PM
    Our Design-Build partner is asking us to sign-off on the coordination model. The BIM execution plan already indicates the model coordination is the Trade Contractor's responsibility & they need to sign off. Anyone have any experience w/ this request. Seems they are treating this as a "submittal" rather than a coordination tool.
    Janene Christopher AIA
    Steinberg Hart
    San Diego CA
    New event: Firm Management Symposium, October 1-2, 2026, click here to learn more
  • 2.  RE: BIM Coordination Model and Design-Build
    Posted 05-05-2025 09:57 PM
    The Contractor is trying to get you to take responsibility for the model, just as if you had created it. You should have had everyone wanting access to the model to sign a document releasing you from any liability from the use of your model. If everyone that contributed to the model did as I stated above the next step would be to verify that you are protected in the state the project is being built in. If so I see no need to refuse but if not I would not sign anything other than your original Agreement. I hope you carefully reviewed the original Agreement, Design/Build can be a risk rich contracting type for Architects. Contractors will try to have you take responsibility for the design of others that you include within your design. Don't ever agree to that.
    Good Luck,
    E. Michael Stanley, AIA , LEED AP
    E. Michael Stanley AIA Member Emeritus
    Scottsdale AZ
  • 3.  RE: BIM Coordination Model and Design-Build
    Posted 11-20-2025 05:02 PM
    The contractor is trying to shift full responsibility for the model to you, as if you created it. Anyone requesting access should sign a release of liability for its use.
    Thesla Collier
    HNTB
  • 4.  RE: BIM Coordination Model and Design-Build
    Posted 05-07-2025 09:24 AM
    Sticky situation to be in when in a design-build relationship since you technically are working for the contractor. Glad to hear you have a BIM execution plan. For our office, once the BIM model is out of our custody, we do not take it back and claim it as our own. When we do provide the BIM model to someone, we have them sign a release. This is our template that we customize for each situation:
    I know it may be too late to incorporate it for your current situation, but this might be good for future work with this DB partnership.
    Bridgett Wakefield AIA
    Reifsteck Wakefield Fanning & Company
    Champaign IL
  • 5.  RE: BIM Coordination Model and Design-Build
    Posted 06-19-2025 03:59 PM
    thank you!
    Steinberg Hart
    San Diego CA
  • 6.  RE: BIM Coordination Model and Design-Build
    Posted 08-28-2025 05:11 PM
    It's reasonable to push back on signing off on the coordination model if your BIM Execution Plan (BEP) clearly assigns that responsibility to the Trade Contractor. In a Design-Build setup, roles can blur, but the BEP should serve as your contractual and procedural guide. Signing off could imply acceptance of liability for coordination outcomes you didn't control, especially if the model has evolved beyond your scope.
    One way to address this is to reaffirm your role as the model originator, not the coordinator. If your team has already issued the model with a release or disclaimer (as some replies suggest), you might reference that document and offer to confirm only that the model was shared in accordance with the BEP. This keeps the focus on process compliance rather than ownership of downstream coordination. If needed, you could propose a joint sign-off format that clearly distinguishes between design intent and construction coordination.
    • Revisit the BIM Execution Plan and your original agreement for role clarity.
    • Confirm whether a model release or disclaimer was issued and acknowledged
    • Consider proposing a non-liability acknowledgment or joint sign-off format
    Thesla Collier Intl. Assoc. AIA
    HNTB
    Newhall CA
  • 7.  RE: BIM Coordination Model and Design-Build
    Posted 11-20-2025 05:01 PM
    I agree with you. The BIM Execution Plan clearly states that coordination responsibility lies with the Trade Contractors, so they should be the ones signing off. Treating the coordination model as a "submittal" shifts accountability in a way that doesn't align with the agreed process
    Thesla Collier
    HNTB
